so it sounds more and more like it's not losing oil pressure only the indication? if you think that's the case then try to blow out whatever might be in there. that would be a strange one because liquids are practically incompressible and the slightest bit of pressure should show on the gauge...something would have to be acting like a perfect check valve.
certainly need to share what you find to be the problem
