The Haze 8.02 @ 174+ twin turbo 452"
B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60'
Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only.
JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164
"Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156
Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04
Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG
NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph
MR P BODY 9.47@142.5 395 ci W-2 2430#
acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137
440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID
Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor
Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam
StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor.
daron 73 duster 10.50 et @ 127.00 sb street car
TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust
LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas
aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto
w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver
440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street
493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57
68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car
topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft
cudadan, 12.02 at 110 with a 1.58 60ft
quickd100, 1.595 60ft. 7.621@87.04-1/8 12.19@105.88 1/4
Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4
Greg J,12.466 @ 108.98 (1.764 60')69 Road Runner 3850 # w/driver, 446
