Thanks Dr. Diff!!
I checked at the local Napa for the 67 Ford 1/2 ton pickup with 9.75 dana. The seals listed for it fit!
They are Napa part # 15142 for those of you who may need them. They are a little smaller than the ones the parts book listed that wouldn't fit, just like the doc said.
Also, some more info for you guys doing your own boogie with a dana 60. I needed a "speedy sleeve" for the yoke (a sleeve that fits over the groove worn in the yoke by the seal and 30 plus years of use). All three parts stores in town listed the sleeve, no one had it in stock, but were glad to order it for me, at the cost of around $25-$30 bucks. I asked a lifelong parts man about a sleeve, he looked at it, says "I think I have what you need" (didn't look it up) walked back up from the back with Carquest # A226-2 sleeve, fit perfect, $6 bucks!!
One last thing, Dr. Diff, the axle bearing locking collar is still available by itself, Timken # K108601 (from A&W Bearing in Texas).
Thanks for the help guys.
jt
