Take your pic...Up top or down low...BPE or Classic auto air are the best bets for the parts...Here's a set-up with the classic auto air bracket up top...Best advice I can give is : If you use either companies upper bracket set-up make a belt guard for the compressor using the two upper compressor holes...The adapter ring/seal is right there...
