Looks great! I don't know how hp #'s compare from turbo to roots supercharger but we dynoed my 540 BAE fathead fully moded k-11 superman @50 over. Best #'s were 2153hp.It was to lean for what we need.So we had to add fuel. It was living well in the 1800hp range on the dyno. I heard all kinds of numbers before we ran it but thats what it made.I would be very interested to here some real world dynoed turbo motor numbers.Good luck with your combo!My motor was 39lbs of boost. What version of brads heads are you running?
We are running BA-8 alcohol heads.
Our SBF/135 procharged deal went 6.61/213 at 2750 pounds and 430 cubes on Q16. I think that figures out to something over 2000 HP. The 136 P/charger is supposed to be a lot better than the 135. We have 70 more cubes, heads that flow well over 100 CFM more and we're using M5. We'll see. Yeah HP numbers are often exaggerated. If we make close to 3000 I'll be real happy.
