I have switched my car from the points system to the MSD all in one electronic ignition. new coil, wires,plugs. Do I need to put a different voltage regulator on the car now? Or change any wiring? The car starts on 4 cyl sometimes and just dousnt seem to run right. Some of this issue may come from the carb not choking when cold. Just looing for some pointers. Thanks, Ken
