Thanks for the input guys! I ended up using an S.O.S pad and it worked fine where the old silver was. Wiped with alcohol then paint. On the top of the grille where it lips over the striker plate, I had to use 600 grit paper because someone had spraypainted it flat black. after Sanding, I polished it. No hemicuda, but I think it suits my discerning eye.
