And i dont hink you need calvert springs to make it work, they are just single leafs witch help unsprung weight.
Aldough i believe you need a "weak" spring with alot of wrap up to make it work good.
I just traded out my "weak" original 6 cylinder springs for the Cal-Trac mono's and I have to say that the car 60fts slightly better but it is far more consistent at this point (1.397/1.385/1.396). When I weighed the mono's against the stock springs it was just a few pounds lighter per side. As much as I hated shelling out the $400, I will have to say that the monos were a good investment. With the whole set-up together Cal-trac, mono, ranchos and 90/10's I feel confident in making adjustments and the car is working better now than ever. I see a consistent 1.35 60ft in my future.
