Ditto on the kickdown. Sounds like it isn't adjusted properly. What it's doing is going through the gears one right after another without any delay. Don't drive it like that for long or it will need a rebuild soon.
If it's adjusted right, you should be able to see the throttle control lever on the transmission move back when you pull back on the carburetor linkage.
Kickdown Adjustment
