Searching for reasons why I've burnt out my 2nd set of low clutches in 3 years.
If the drive shaft bottomed out on the launch when everything winds up, could that be putting pressure on the clutches and frying them? Not sure how much play I have as the tranny is already sitting on the garage floor, but will be putting it back in to check the spine depth.
Any other ideas?
