For those of you with front disc brakes...how are you keeping the rotors looking new? They will start looking bad right away if I install them right out of the box. The temps will be very high so I'm guessing RPM will just burn right off. How about masking off the pad contact surfaces and spraying them down with a high temp clear?
What are you using?
