Ive yet to see any parts store that has the correct puller for them.I have one in the garage and the rear brakes arent that bad to do once you do them.Just dont use a jaw puller or you will have instant junk for drums.I bought a 61 that some moron did that too.It was a 1 owner no rust low miles super clean car.Guy couldnt figure out why after the Mechanic he had that tore the drums off it would shake so bad the pedal jumped.I found some good drums at a local yard and cut them anddd it was fine.Rocky
The puller shown is a sears hub puller and it will work.
