I am looking to add a limited slip to my 95 Dakota when I put gears in it.A friend says trac locs are weak and I should go to an auburn unit.
Any thoughts??Who makes the sure grip unit that mp sells for the 8.25?
Bear in mind this is a 3.9 5 speed with very minor mods done so it won't be stressed and don't know if it will ever see a drag radial.
I am tempted to go gears only and run one drag radial to see the embarassing times it is capable of.
