I just ordered some. They're similar, same number of teeth, teeth are shaped the same, etc.
The big difference is the width of the teeth. The roller style has wider/thicker teeth, wide enough to where they will not fit on the non-roller chain.
On the other hand, the thinner tooth non-roller gears could "potentially" be used on the roller chain but probably not a good idea.
Rich H.
Esse Quam Videri
