Quote:Quote:Based on ship weight from Grainger on 100ft, 2/0, 1/0 and 1 gauge wire. The weight per foot on each is: 2/0 = .491/0 = .391 = .31So a 10 foot run of each wire won't vary more than about 2 pounds. Not real significant. True, I checked it - but if you are using #0 welding cable, the weight difference will be significant.
