If your using the EFI the cheapest way is to convert it to the GM LS ECU and program that. I am looking into this.
Will you tell us a little more about this?
Little info I found out is that the total package is 2500.00.
Google Nutter Racing.
I want to try to make my own toner ring and camshaft ring .
Get the.computer and build my own harness.
May just buy the whole kit.
When i was getting a quote from arrlington for his oem computer, harness and pedal to keep the drive by-wire sete up it was around the 2500 price. So given the mopar stuff is the same cost as the chevy i think i will stick to a mopar set-up.
Nothing wrong with the mopar ecu.
The LS is cheaper more plentiful and fully programmable.
