Nice info. Just a note, prior to 1998, crown vics had 15" rims and 1998-2001 Crown vics had 16" rims and a different offset to their rims. 2002-current had a flush mount rim due to change in suspension design. Thunderbirds from 89-97 all though 5 lug, were a 5x4.25 bolt pattern. Prior to that, they were 4 lug. The Lincoln MKVII I believe were 5x4.5 and came with aluminum spares, but in a 15". Other than that, I do like the homework you did.
