We put a late K-frame in our old 64 Plymouth, modified the crossmember by building a new box for a later trans mount, but the original driveshaft didn't fit. Found one at the junkyard that fit after we moved the rear foward an inch by using the rear spring perch holes (another old trick for improving weight transfer...)
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
