Quote: This is a good question , i was also wondering about the max tire size i can run on the rear of an e-body. I'm running 265 60 (26")on the rear and with the air shocks it looks like i could run a 28 or 29" . With 4:10 gears the taller the better until i change gears or buy a tremec OD
On my '73 cuda,I'm running ET street radials 295/55-15(28" tall) on a 8" rim. 295/65-15(30" tall) looks like it would work also.
