It was a good running car that did consistent 10.20s in a peruvian track that was not the best, so I decided to loose some weight instead of going for a bigger motor. It was hard to make the first cut but after that it only took a couple of days to remove the old rollbar, the complete floor and the old frame. Here's some pictures so you guys can critique my work
