Re: Sure Grips and Cornering
[Re: DoctorDiff]
#1207346
04/03/12 04:10 AM
04/03/12 04:10 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
From http://www.torsen.com/products/products.htm : Quote:
Torsen differential products cover a wide range of torque biases and applications in the front, center, and rear of a vehicle!
T-1 (Type A) This is the original differential that was introduced in the AM General HMMWV (Hummer®) and the Audi Quattro which has seen considerable growth in other worldwide applications. This is our crossed axis helical (Invex™) higher torque bias differential.
T-2 (Type B) This differential is only a few years old and adds a wide range of torque bias coverage for the Toyoda-Koki Automotive Torsen North America, Inc. product line. This type of differential is referred to as our parallel axis helical (Equvex™) differential which was designed to accommodate Ford and GM C-Clip applications.
T-2R (RaceMaster) The T-2R is a higher bias T-2 torque sensing parallel axis differential designed for the more performance minded driver. The higher bias found in the T-2R, like the T-1, allows the transfer of more available torque to the wheel that can better use it.
T-3 (Type C) The newest differential style of the Torsen product line. The T-3 is currently offered in a single or Twin Differential configuration (The twin differential has an open differential surrounded by a Torsen differential!). This versatile unit is ideally suited for center applications and is designed for those hard to package all wheel drive systems. The design of the Type C allows for a torque split other than 50:50 with a majority of available torque designed to go to either the front or rear axle.
From http://en.wikipedia.org/wiki/Torsen :
There are currently three types of Torsen differentials.
The original Torsen T-1 (Type A) uses crossed axis helical gears to increase internal friction. The Type I can be designed for higher torque bias ratios than the Type II, but typically has higher backlash and the potential for Noise, Vibration, and Harshness (NVH) issues, and requires a precise setup/installation.
The later Torsen T-2 (Type B) uses a parallel gear arrangement to achieve a similar effect. There is also a specialist application of the T-2, known as the T-2R (RaceMaster).
The latest Torsen T-3 (Type C) is a planetary type differential, in that the nominal torque split is not 50:50. The Type C is available as single or twin version; the Torsen twin C differential has front and center differential in the same unit.[2]
