Overly wide tires will do it also. My '66 is aligned well with all new suspension and it still follows the ruts somewhat because I am running 245/60s in the front. Much wider than it was designed for. Even my new Infiniti G35 does it because of the wide tires. My old BMW 325i also did it. The suspension on all those cars are tight, but they all run wide tires.
