Ok, so for the sake of discussion, I set the total timing to 36, you are saying I need to set for say 37 or 38 to allow for the delay? Or if I wanted 18 initial, set it for 20 or 21? How do you figure what the delay is? I may be making this harder than it is.
No... you set it to what you want... your looking
at the end results when your using the timing light
Thanks, that is what I thought, just having a problem with this delay thing. I could see it if you changed the box and then didn't check the timing. I suppose I was over thinking this. Which is hard to believe, have a hard enough thinking about it the first time. but anyway thanks for clearing that up.
