I would get the correct KB pistons & get .040" quench which will let you run a higher SCR on the exact same octane WO pinging and squeeze is one of the #1 parameters of how much power an eng will produce. first decide what octane you will be running and a conservative compression ratio will let you run an aggressive ign curve staying under the pinging point also very important for power
"using stock short block"
