What intake , what did you do about the 2bbl Throttle linkage , did you reuse it as is?
The last stupid question , what modifications did you do to the transmission ?
This is a 5.9 Magnum so the intake is an AirGap. I did reuse the 2V carb adapter but I modified the kickdown rod linkage so it would reach the carb in a similar fashion as before. There were no mods made to the transmission because my plan is to swap it out for an OD unit later this year.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
