It's a stock, cast-iron intake that was used on '69 383s. I could probably shoot some ether around the gasket flange to make sure I'm not getting a leak there....
BTW - again in case it makes a difference, I'm running a Pertronix setup (electronic distributor and ignition coil, no ballast resistor).
