check your linkage...
I've been thinking, this is on a 72 Cuda. When I got to the point of putting the rod between the floor shifter and the arm on the tranny I wasn't sure if the part that had the adjustment on it went on the shifter part or the tranny arm. I have it on the shifter arm, any thoughts?
