If the u-joints in the 727 slip yoke are the same as the u-joints in the driveshaft you will just have to shorten the driveshaft four inches. If the u-joints in the slip yoke and rear end yoke are different you'll also have to use conversion u-joints.
The INTERNET, the MISinformation superhighway
