Can anyone tell me if the carb stub and nut from a 1971 challenger 318 2 barrel is the same for a 72 340.
Dantes is out of stock and I have the old set up from my 318, wondering if it will work??
Jims Auto parts has this listed and it makes me think they are the same.
CARBURETOR TO THROTTLE CABLE STUD
(for mounting accelerator cable & auto kickdown linkage & throttle return spring)
EG-1049 Auto Trans 2 or 4 Barrel $ 24.95 ea.
http://jimsautoparts.com/engine_fuel_parts.htm
Thanks again for the help
Yes it is the same , same part for all engines .
And haven't read enough bad things to not even bother going to Jim's ?
