Rocker shaft shims are for correcting incorrect rocker arm to valve tip geometry not for setting lifter preload.
I understand and agree. But is there any harm in using it for adjusting preload as long as it doesn't adversely effect valve tip geometry?
They will effect geometry even if a small shim is used, watch what your doing. If you use to much you could put extreme side load on the guides and wear them out.
logan426
