Ive been doin some serious googling and some say the output shaft is too short to just bolt on a new tailshaft. Is this true or was i mislead?
On the OD trans the OD is inside part of the tail housing , you need to have the entire tailhousing with OD inside it ... most parts are the same , the output shaft of the OD unit itself is different ... and you aren't going to be finding it for 65 bucks unless it's junk .
