Guess I should clarify since after I read it,it looked a bit confusing.
The new 10gauge wire is from the back of the alternator to the new distribution block only.
From the 20 amp fused distribution block,I am using I think 12/14 gauge wire for main power to the relays.
Out of the relays to the headlights themselves is just the stock wiring.
Sounds like we may be good to go though,thanks.
1978 Round Up-1977 Warlock-1977 Powerwagon Adven.- 1976 Blue "Macho"-1974 Charger-1968 Fury III -1966 Newport *
