First thing do not forget to pull the speed sensor out of the trans. Pulling the right side driveshaft is a female dog if you forget. Secondly disconnect the sway bar from both lower control arms. If you don't, it's a real problem to get the lower control arm dropped down enough to get the ball joint to separate. Oh, make sure you have a pan under the transmission when you pull the driveshafts and don't screw up the oil seals in the transaxle when you pull the driveshafts.
"We live in a time when intelligent people are being silenced so that stupid people won't be offended".
