i had a world hemi cast block years ago that leaked from the rear seal. after dropping the pan 4 times, i discovered the groove in the block was machined too wide & not centered to the crank. the seal would slide in real easy, then get snug when it was about 1/2" from being flush with the block. chrysler wanted it back & sent me a new one. just sayin. seeya.
