Quote: Good find but after viewing the first video you need new wires. # 7 was arcing Bad against the valve cover Matt
Um...they're brand new Firecore 50s, haven't even driven them yet. and where did you see arcing on the #7 plug wire I don't even see the #7 plug wire in the first video....
MY BAD # 8 around 1.22 into the vid. It LOOKS like it is arcing. Maybe I'm wrong.
Ok, now I see it. I don't know....I'll have to ohm check the wire I guess, might have a bad one. if it is bad, I have no doubt that Rick will take care of it for me. like I said, this is a brand new set, zero miles, the only run time is the initial fire up on the engine and trouble shooting this sound.
I don't know that it's spark arching though, because that was a very rapid flashing, WAY faster than the engine RPM. not saying it's not the plug wire arching, but I don't see how it can be arching that "fast" when the engine is at idle
