Nope. There are two sets of outer holes. The buckets use one set the bench uses the other. There are usually 1/2" plugs that fill the holes. I attached a pic of my 69 GTS, the bucket holes are on the inside and the bench holes are on the raised portion.
JB Rhinehart, Realist
A-Body's RULE!
