I almost went at this project before remembering I need a different throttle bracket and possibly a different upper transmission link.
This is a Performer manifold and a Carter AVS going on a 1967 automatic Coronet originally set up with a 2 barrel Carter BBD. I am using an adapter with the manifold, but just the thin 1/8 in. plate type, not a thick spacer type.
From what I can tell just from searching, I should get the Eddy 1843 or 1481 throttle bracket adapter (apparently it's just a color difference?) and possibly one of their rod extensions?
I also found mention of Eddy part no 8021 for a 2-4 bbl 318 conversion, but some list it for early Holley double pumper setups which is not the OE carb on my car by any measure.
I don't really have any means of fabricating anything short of bending things with pliers and cutting things in half so I'd rather just buy a couple of pieces and be done with it.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
