I know that one of the yellow from the dome light harness is
connected to the dimmer switch and also to the door switch.
How or what role does the dimmer play on the dome light functionality.
Also is there 12 volts running on the entire circuit including both door switches and dome light harness and how does the door switch's
activate the dome light.
