Re: 440 Dynamic Compression and Pump Gas
[Re: 7e5dartsport]
#1179448
02/20/12 12:13 AM
02/20/12 12:13 AM
Posts: 1,880 Out in Left Field, NY
bobs66440
i use wallace racing`s calculator. i have my own formula to calculate dcr and both give me 7.12 or 7.13 dcr. input numbers to plug into the wallace racing calculator are bore=4.35, stroke=3.75, rod length=6.768, static cr=9.35, altitude=0, boost=0, 8cylinders and intake closing point=70*. it should give you the same results as mine.
You're right. I was giving a 7.768 rod length by mistake. Sorry.
Thanks for your help.
