"Best" and "Duplicolor" probably should not be in the same post...
Just covered this in class today.
Plastic parts tend to build up static. There is a product for this.
Then clean with water-based wax and grease remover, not solvent. Spray wet, wipe cleanly off, dry with new towel.
Tack cloth, then adhesion promoter, then spray.
