I have been thinking of putting my original 318 back into my 68 satellite. How can I get more power out of the engine before I put it back in?
Several ways you can go but, as said it also depends on your budget. On the cheap I would go Summit K6900 cam. Also, the 360 RV cam I hear is a good one don't forget to degree it in. Summit Headers, a good ignition system, a good timing chain, Weiand 8007 intake or Edelbrock Performer topped off by a 800 Thermoquad or 600 Edelbrock or 600 Holley carburetor.
Then run a 904 behind it and have a low gearset installed with a decent converter and TF1 or TF2 and it should run alright.
