The module is located in the door and is used to cut down on the amount of wiring need in the door to perform all of the functions associated with the door, like the power windows and mirrors, etc... It is separate from the switch and the door panel must be removed for access. Express windows are the one-touch down and/or up with the switch. switch should say AUTO if equipped.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
