Anyone have a 1971 challenger convertible? I am having a problem with the torsion bar that holds the trunklid up. The 71 verts have only one t-bar, not two. It is a larger diameter than the two bar style.My problem is that it holds the trunklid crooked. All of the spring tension is pushing up from the passenger side hinge and this is causing the problem,Even when its closed,it is crooked. Has anyone had this problem? Any ideas on a fix. Thought about fabing up a mount for a standard style spring for the driver side hinge. Was this a problem with all 71 chall. and cuda verts?
