I am going with these, I will have $400.00 in a complete set of front and rear disc's. I had a local shop water jet the adapters for the front and the rears already bolt on. The rotors are 12.44" fronts and 11.21" for the rears. They fit perfectly on the stock drum hub and spindles, they are from the same vehicle and can work in some 15" wheels.
