Guess time: I guess you'll have to open up the pushrod hole on the inside, a higher ratio rocker moves the pushrod towards the center of the cylinder.
Whose 1.7s are you running? I have a set of ford smallblock 1.7s and if the ford 1.6s work on a Mag head they might work also. Anyone try this?
R.
