I was talking about taking the lead from the back of the alternator so the heavy loads did not pass through the factory harness.
I understand the ammeter will not be affected unless the alternator isn't producing and the power has to feed through the harness from the battery.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
