I had something similar when I first dropped in my 360, I had the freaking throttle cable set too tight. Check the small stuff like that, and the vacuum caps, vacuum hoses. Do you have power brakes? I had the plastic cap that goes into the booster crack before, that'll give you a nice vacuum leak. How well is your intake sealing? Did you do the spray test yet around the intake sealing area yet?
