I've always used Windex without a problem....and like hp383 said, don't go excessive with the Windex, just enough to keep the decal from sticking to the surface while you get it to the place you want. That one is small enough you could probably "go comando" and not use anything. Get one edge taped where you want it, remove the backing and slowly work from the taped area outward to stick the decal.
