Quote: Do you know that the 14 inch trim ring #2875758 is special for 1969 because it has a lip on the inner part of the ring. This is the trim ring that should be in demand for Charger Daytona & 500 models (really all 69 models). Galen says it is held on by 4 clips on the back.
Is that the ring that clips over the wheel edge and always runs into a wheel weight?
