This shows the gap at the reluctor. This was run on a dist machine so the gap must be correct but it is just larger than what FBO has run in the past and way larger than the MP spec. I plan on running it this way but I am just trying to find out why this gap is so much larger than the typical .008" from my previous FBO unit. The only guess that I can come up with is that this pickup is another brand. I have read that the MSD magnetic pickups are spec'd out to around .025", so I am guessing that this is a MSD unit modified for a Chrysler harness.
